Invalid operation exception
Mohamed.E.Salem
Mohamed.E.Salem
hi all,
 I face a problem . I tried to use bottom to select familyinstance (column ) then make some changes . the message appears. what should i do ? (Revit 2019.1)
Capture.PNGThank you and best regards,
Salem
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Mohamed.E.Salem,
Are you trying to pick multiple objects using PickObject??
PickObject method will help to pick only single object so try using PickObjects Method.
try using below link
PickObjects
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Mohamed.E.Salem
hi   @naveen.kumar.t
only one object
Mohamed.E.Salem
I should select the object from Revit UserInterface
but when i came back to revit I can't make any selection because the displayForm poped up
that explain null exception
what should i do?
naveen.kumar.t
Autodesk Support
Autodesk Support
Mohamed.E.Salem
Hi @naveen.kumar.t
I tried to use modeless form But i found that Revit API deals with modeless form as external application runing outside API context so i can't make transaction
what should i do ?
thank you In advance
