Invalid number of references
mr.engineer.aec
Message 1 of 9
mr.engineer.aec
 Hi guys,
I try to create dimension from references planar face of Beam.
But i can't. Warning "Invalid number of references".
dimension References. Size = 4.
How can i solve this issue ?
 Thank in advanced.
Code:
var beamFaces = GetSolids(beamInstance)
                    .SelectMany(x => x.Faces.OfType<PlanarFace>())
                    .ToList();
                var verticalFace1 = beamFaces
                    .Where(x => x.ComputeNormal(UV.Zero).IsAlmostEqualTo(-1 * Doc.ActiveView.RightDirection)).ToList();
                var verticalFace2 = beamFaces
                    .Where(x => x.ComputeNormal(UV.Zero).IsAlmostEqualTo(1 * Doc.ActiveView.RightDirection)).ToList();
                foreach (PlanarFace pl in verticalFace1)
                    dimensionReferences.Append(pl.Reference);
                foreach (PlanarFace pl in verticalFace2)
                //MessageBox.Show(dimensionReferences.Size.ToString(),"Test");
                XYZ pickpoint = UiDoc.Selection.PickPoint(ObjectSnapTypes.Points, "Pick point");
                Line dimensionLine = Line.CreateUnbound(pickpoint, Doc.ActiveView.RightDirection);
                using (Transaction transaction = new Transaction(Doc, "create dimension"))
                    transaction.Start();
                    Doc.Create.NewDimension(Doc.ActiveView, dimensionLine, dimensionReferences);
                    transaction.Commit();
Replies (8)
Message 2 of 9
mr.engineer.aec
Message 3 of 9
jeremytammik
Well, four seems like rather a lot.
Don't you just want two faces to define the dimension between them?
If so, you might want to filter your four faces further to determine which of the two you want to dimension and which two to ignore.
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 4 of 9
mr.engineer.aec
 Hi Mr. @jeremytammik
Thank for your reply my topic
I want to get all faces (4) to dimension.
Can Revit API retreive them ?
Many thanks for your reply.
Message 5 of 9
jeremytammik
Message 6 of 9
CJModis
The fact that you have 4 elements in the array does not mean that you have 4 reference in the array. Here in this line, null may well get into the array:
Did you remember to specify the property ComputeReferences = true; when you received the geometry?
Message 7 of 9
mr.engineer.aec
Thank for your suggestions, Mr. @jeremytammik
Message 8 of 9
mr.engineer.aec
 Hi @CJModis
It is as you say. I have a problem about append Refferences to RefferenceArray.
Many thanks for your suggestion.
Message 9 of 9
ryuzaki2005
i did nit try. But you can try like this :
string sam1 = planarFace.Reference.ConvertToStableRepresentation(Doc);
string Refer1 = sam1.Replace("SURFACE", "LINEAR");
Reference pl = Reference.ParseFromStableRepresentation(Doc, Refer1);
which each Reference. Because Reference of PlanarFace is REFERENCE_TYPE_SURFACE not REFERENCE_TYPE_NONE or _LINEAR.
