Invalid Number of references
chau.nguyen92
chau.nguyen92
Hi I wanted to create an aligned dimension. I followed exactly as Revit API docs:
Autodesk.Revit.DB.Line line = Autodesk.Revit.DB.Line.CreateBound(location1, location2);
ReferenceArray refArray = new ReferenceArray();
refArray.Append(line.GetEndPointReference(0));
refArray.Append(line.GetEndPointReference(1));
doc.Create.NewDimension(
doc.ActiveView, line, refArray);
However, I received error Invalid Number of references. I used revit 2018.2
I have searched for this problems and see solutions on other forums. I tried to cast the start point and end point to reference but still receive the same error. Thanks in advance!
MarryTookMyCoffe
in revit lookup you can see that reference is null, use start point and end point
do not worry it only gonna take Autodesk 5 years to fix bug
RPTHOMAS108
Just as in the UI I don't think you can dimension a line that isn't from actual geometry.
i.e. you need to create a DetailLine or ModelLine (both derive from CurveElement) and add the references to the array from those i.e.
Document.Create.NewDetailCurve(View, Line)
or
Document.Create.NewModelCurve(Curve, SketchPlane)
Then
CurveElement.GeometryCurve.GetEndPointReference(EndIndex)
chau.nguyen92
Yeah I tried different ways. Tried what MarryTookMyCoffee suggested but only adding new detailcurve works. Odd that the Revit API example not working. Thanks
