Intersection area between a Shaftopening a floor
How I can calculate the intersection area between a floor and a shaftopening. I can not delete any object.
Javi
jeremytammik
Dear Javi,
You might be able to determine the edge loops of the floor, including loops around inner holes, e.g., the hole generated by the shaft opening.
Identify the loop caused by the shaft and calculate its area:
http://thebuildingcoder.typepad.com/blog/2008/12/2d-polygon-areas-and-outer-loop.html
From now, on, please search for yourself before raising any more questions.
Everything you have asked has already been discussed by The Building Coder and here in the forum in previous threads.
Thank you!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Hi again,
The problem that I have it is how I can know if a shaftopening intersect with a floor, because its property Host in equal null.
Yours,
Javi
jeremytammik
If you can get solid geometry representing the shaft, get that.
If not, use something else, e.g., geometric lines along its edges or something.
Grab the solid of the floor.
Calculate the intersection of the two.
Check out my recent discussion on retrieving intersecting elements:
http://thebuildingcoder.typepad.com/blog/2018/03/create-2d-arc-and-filter-for-intersecting-elements....
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Thanks for your advices. Finally, I uses the geometry of shaft opening to check the intersection.
Thank again,
Javi
pavelkosykh88
But if shaft already cuts geometry from the floor, there will be no intersection.
Am I wrong?
