Intersect solid and plane
sonicer
sonicer
How can I get the curve that is result from intersect solid and plane?
I am using this:
   Plane plane =  new Plane(XYZ.BasisZ,point);
   Solid cast = BooleanOperationsUtils.CutWithHalfSpace(solid, plane);
But don't know is the right way....?
thx..
FAIR59
from the resulting solid (cast) find the face with normal (0,0,-1). The edges are the required curve(s)
                SketchPlane skPlane = SketchPlane.Create(document, plane);
                PlanarFace CutFace = null;
                foreach (Face face in cast.Faces)
                    PlanarFace planFace = face as PlanarFace;
                    if (planFace == null) continue;
                    if (planFace.FaceNormal.IsAlmostEqualTo(XYZ.BasisZ.Negate()) && planFace.Origin.Z == point.Z)
                        CutFace = planFace;
                if (CutFace == null) return Result.Failed;
                CurveLoop _boundery = CutFace.GetEdgesAsCurveLoops().First();
                foreach (Curve c in _boundery)
                    document.FamilyCreate.NewModelCurve(c, skPlane);
Revitalizer
Hi FAIR59,
I think that there may be more than a single Face in the result.
E.g. if cutting an "O" shaped solid into a half, making a "C", there will be two intersection faces on the "C"'s endings.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
FAIR59
Hi Revitalizer,
you're right. To find all the curves in the plane, you need to make a list of faces that pass the test, instead of the single CutFace.
And of course you'd need to process every Curveloop in the FoundFace.GetEdgesAsCurveLoops(), instead of only the first.
