Announcements
Installing Revit Shared Reference Point 2022
malbitz
malbitz
We are using SCCM/MECM to deploy our apps and updates.  19-21 Share Reference Points are msi installs.  2022 is an exe that extracts to a temp folder and runs a setup.exe.  I will able to harvest the setup from the temp folder as no switches worked in SCCM to install the self extracting exe.  I cannot figure out the switches for the setup.exe to install it and make it silent.  Any help would be great.  I have tried the normal /? -? --? and the new --install_mode install --quiet and tons of other things.  Thanks
jeremy_tammik
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
So, you cannot expect an answer to a question such as yours relating to system requirements, installation, product setup, optimisation, usage or other end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to address this topic than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
malbitz
Yeah.  Sorry about that.  I found the correct place after posting this.  Thanks!
