Hi all,
We've been struggling here in South Africa with the installation of Revit Content Libraries (since the 2015 release). The 2016 release is particularly bad as it seems that most users can't even manage to install the libraries at all.
We constantly have to navigate users to the uninstall programs feature of the control panel (reference post: http://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/...
This should not be necessary, AND it usually doesn't work (probably due to unstable internet).
Much appreciated.
Kind Regards,
Anria
Solved by porterja. Go to Solution.
direct link to autodesk material library
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Hi anriae,
Thank you for contributing to Autodesk Revit Answer Day!
The link in the original post appears to be broken, but to verify, here is a link on how to install Revit content - Revit: Templates and families not installed
You can find the direct installation for the Revit content HERE.
NOTE: The default location of the files should be: C:\ProgramData\Autodesk\Product (Revit 20xx), unless a different location is specified during installation.
Here is how to Select Content for a Revit Installation.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Thanks for the reply,
Again the slow internet connection won't allow me to verify the link you sent, but thank you for the direct download link. Does this include the South African Metric Library?
We'd still like to be able to do installations only from the installation media (without needing to download GB's worth of content), just putting it out there.
Thanks though,
Good luck with the rest of Answer Day.
thank you for the blog.. issues with the internet speed are common in African especially here in East Africa.
Am writing to re-request for the direct link for the revit 2016 content Library as the ones given above have an error of 404 which reads the content was removed.. i would be very glad if i hear fro you soon.
