Inserting Level based family within a family document, prior to Revit 2024
alanmlevy
alanmlevy
I was trying to add a level based family (e.g., structural column) to a family document in Revit 2023, but I see that there is no method in FamilyItemFactory that includes level. I did notice that Revit 2024 has added a method to FamilyItemFactory that includes level, but I am not yet using Revit 2024. Is there any way to accomplish this in versions prior to Revit 2024?
Mohamed_Arshad
Hi @alanmlevy
Are you trying to place a column in the family document?
Mohamed Arshad K
Software Developer (CAD & BIM)
alanmlevy
Yes that's correct.
Mohamed_Arshad
Hi @alanmlevy,
  As you mentioned, there is no direct method for Inserting a Column in FamilyDocument for Revit 2023 and lower versions too. In 2024 it has been updated.
  But using NewFamilyInstances2( List<FamilyInstanceCreationData> dataList) you can Insert a column in Family Document. Kindly check the below code for additional reference.
Reference Code:
  using (Transaction insertColumn=new Transaction(doc,"Insert Column"))
                insertColumn.Start();
                if(!sym.IsActive)
                    sym.Activate();
                FamilyInstanceCreationData data = new FamilyInstanceCreationData(new XYZ(0, 0, 0), sym, level, StructuralType.Column);
                doc.FamilyCreate.NewFamilyInstances2(new List<FamilyInstanceCreationData>() { data });
                insertColumn.Commit();
Hope this will Helps 🙂
Mohamed Arshad K
alanmlevy
I didn't think to use that, but it looks like it should work. Thanks!
alanmlevy
Do you happen to know if there is a way of determining if the Family/FamilySymbol is level-based without doing try/catch on the error? I didn't see a method or property that would tell me that in either of the Family or FamilySymbol classes.
Edit: Never mind, I think I found it - the FamilyPlacementType Property under the Family Class.
