Insert Column
gustavosanmartin
Insert Column
gustavosanmartin
Hi, I'm starting C# programming and I'm trying to run this code to understand how it works. I'm interested in being able to insert columns. Can you help me understand why I can't run it. Thank you so much
#region Creando un pilar Metodo 2 ICollection BatchCreateColumns(Autodesk.Revit.DB.Document document, Level level) { List fiCreationDatas = new List(); ICollection elementSet = null; //Try to get a FamilySymbol FamilySymbol familySymbol = null; FilteredElementCollector collector = new FilteredElementCollector(document); 1ICollection collection = collector.OfClass(typeof(FamilySymbol)).ToElements(); foreach (Element e in collection) { familySymbol = e as FamilySymbol; if (null != familySymbol.Category) { if ("Structural Columns" == familySymbol.Category.Name) { break; } } } if (null != familySymbol) { //Create 10 FamilyInstanceCreationData items for batch creation for (int i = 1; i < 11; i++) { XYZ location = new XYZ(i * 10, 100, 0); FamilyInstanceCreationData fiCreationData = new FamilyInstanceCreationData(location, familySymbol, level, StructuralType.Column); if (null != fiCreationData) { fiCreationDatas.Add(fiCreationData); } } if (fiCreationDatas.Count > 0) { // Create Columns elementSet = document.Create.NewFamilyInstances2(fiCreationDatas); } else { throw new Exception("Batch creation failed."); } } else { throw new Exception("No column types found."); } return elementSet; } #endregion
jeremy_tammik
Welcome to the Revit API! Are you interested in history? Here is a lesson from 13 years ago:
https://thebuildingcoder.typepad.com/blog/2009/02/inserting-a-column.html
I'm afraid one or two things have changed since then.
Before addressing this programmatically, I hope you have tried it out manually in the end user interface to understand the basic BIM principles involved.
gustavosanmartin
Thank you very much for your answer, I have looked at the code that you have provided me and I have been able to arrive at the following. The problem I have is that I can't insert a column and I don't know what the problem could be.
// Obtener el documento actual y la aplicaciĆ³n de Revit
            UIDocument uidoc = commandData.Application.ActiveUIDocument;
            Document doc = uidoc.Document;
            // Seleccionar la ubicaciĆ³n de inserciĆ³n del pilar
            //UIDocument uiDoc = new UIDocument(doc);
            // Pedir al usuario que seleccione un muro
            Reference wallRef = uidoc.Selection.PickObject(ObjectType.Element, new WallSelectionFilter(), "Selecciona un muro");
            // Obtener el muro seleccionado
            Wall wall = doc.GetElement(wallRef) as Wall;
            // Obtener el nivel correspondiente al nivelId de un elemento
            ElementId levelId = wall.LevelId;
            Level level = doc.GetElement(levelId) as Level;
            // Imprimir el nombre del nivel (si se encontrĆ³)
            if (level != null)
                TaskDialog.Show("Nivel correspondiente", "El nivel correspondiente es: " + level.Name);
            else
                TaskDialog.Show("Nivel correspondiente", "No se pudo encontrar el nivel correspondiente.");
            XYZ columnLocation = uidoc.Selection.PickPoint("Selecciona la ubicaciĆ³n del pilar");
            TaskDialog.Show("Revit", "Coordenadas del Pickpoint: " + columnLocation.ToString());
            string columnName = "Columnas";
            // Definimos el tipo de pilar que queremos insertar
            FilteredElementCollector columnCollector = new FilteredElementCollector(doc);
            ElementFilter columnFilter = new ElementClassFilter(typeof(FamilySymbol));
            ICollection<Element> columnTypes = columnCollector.WherePasses(columnFilter).ToElements();
            FamilySymbol columnSymbol = null;
            foreach (Element elem in columnTypes)
                FamilySymbol sym = elem as FamilySymbol;
                if (sym != null && sym.Family.Name == columnName)
                    columnSymbol = sym;
                    break;
            TaskDialog.Show("Revit", "columnSymbol: " + columnSymbol.Family.Name.ToString());
            doc.Create.NewFamilyInstance(columnLocation, columnSymbol, level, StructuralType.Column);
pyaezoneas
You need to use transaction to make changes to a document.
Put your doc.Create.NewFamilyInstance under transaction.
using (Transaction columnInsertTransaction = new Transaction(doc))
if (columnInsertTransaction.Start("Insert Column") == TransactionStatus.Started)
columnInsertTransaction.Commit();
gustavosanmartin
Thank you very much for your answer, I had solved it this way considering what you mention.
            string columnName = "Columnas 6x6";
            // Buscar el FamilySymbol correspondiente al tipo de familia de columna que deseas insertar
            FilteredElementCollector col = new FilteredElementCollector(doc).OfClass(typeof(FamilySymbol));
            FamilySymbol columnType = col.FirstOrDefault(e => e.Name.Equals(columnName)) as FamilySymbol;
            // Verificar que se encontrĆ³ el FamilySymbol correspondiente
            if (columnType == null)
                TaskDialog.Show("Error", "No se encontrĆ³ el tipo de familia de columna especificado.");
            // Obtener el punto de inserciĆ³n de la columna mediante el objeto de selecciĆ³n del usuario
            XYZ insertionPoint = uidoc.Selection.PickPoint();
            // Crear una nueva instancia de la columna utilizando el tipo de familia de columna y el punto de inserciĆ³n seleccionados
            Transaction transaction = new Transaction(doc, "Insertar columna");
            transaction.Start();
            FamilyInstance columnInstance = doc.Create.NewFamilyInstance(insertionPoint, columnType, doc.ActiveView.GenLevel, Autodesk.Revit.DB.Structure.StructuralType.Column);
            transaction.Commit();
            // Mostrar un mensaje de confirmaciĆ³n
            TaskDialog.Show("Columna insertada", "Se insertĆ³ una nueva columna en la vista activa.");
            #endregion
Type a product name
