Insert a PushButton into an existing ribbonpanel.
minet.axel
minet.axel
I want to insert a button in an existing panel but I have a problem.
I have 2 addins that share the same panel.
I get the ribbontab and the ribbonPanel.
1st addin (loaded first)
RibbonTab: MicroMéthodes
       ribbonPanel: MicroCyclePlus
             pushbutton: Cahier de cycle
                   SlideOut
                          pushbutton: A propos Cahier de cycle
2nd addin (loaded second)
             pushbutton: Histogramme
                   SlideOut
                         pushbutton: A propos Histogramme
The result is not the one I want.
Here is the result:
He tells me he can not create the SlideOut because the panel already contains one by cons, he creates me "Histogramme" in the lower part of the panel.
                   SlideOut
Desired result:
@minet.axel
Like you, i do believe this is possible.
Could you please post the code being used to add these to the ribbon?
Another pair of eyes on the code may help. I don't see why a panel wouldn't let you have two slide outs.
Matt
