Insert a point cloud with API
I would like to know how if it's possible to insert a point cloud with API command.
rosalesduquej
Dear Remyescaffit,
Have you looked over the Samples folder on the SDK, I see there is one called PointCloudEngine, that might give you some ideas on how to implement the command you are looking for. Another good resource I can give you comes from Jeremy Tammik's Blog, The Builder Coder.
Check it out, there is a couple of interesting discussions regarding the use of the Point Cloud API.
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.43
Good luck,
Cheers,
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
Thanks Rosalesduquej for your reply,
I'm a new in API programming and i don't know where i can find the Sample Folder.
Besides, i try to insert a point cloud with this command :
        nuage=PointCloudType.Create(doc,"rcs","c:\\Test.rcs")
but i have the this error message : "Modifying is forbidden because the docuement has no open transaction."
I try to write somthing else :
       Dim t As New Transaction (doc,"Test")
        t.Start()
        t.Commit()
And i Have this error message : "Starting a transaction for an external application running outside of API conext is not allowed"
Can You help me ?
(I find the sample folder)
rosalesduquej
If you are new to Revit API developement I will suggest going over this link http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=16459234
It will give you a lot of knowledge with the starting point on your developement. There is a lot of things that you need to take into consideration when using Revit from the API. So I will suggest go over and start testing some of the samples I refered on the SDK folder.
Best of luck.
Cheers,
Jaime Rosales D.
