Initialize WPF window throw exception
Hi all,
I've been making a small plugin for my Revit project. The plugin will prompt user to a modeless dialog where they select variable to pass into the external event. The dialog is a WPF window, and I use MVVM pattern. I follow the modeless dialog sample in the SDK to initialize my window, however, when I debug my code, Revit kept throwing exception at the ExternalCommand step :"object reference not set to an instance of an object"
My code for ExternalApplication and ExternalCommand is as below, I did almost everything exactly as the example except passing externalevent and its handler to the view model:
class RevitCommand : IExternalCommand
        public virtual Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            try
                ThisApplication.thisApp.ShowWindow(commandData.Application);
                return Result.Succeeded;
            catch (Exception ex)
                message = ex.Message;
                return Result.Failed;
and the application class:
public class ThisApplication : IExternalApplication
        //Class instance
        internal static ThisApplication thisApp;
        //Modeless instance
        private MainWindow m_MainWindow;
        public Result OnShutdown(UIControlledApplication application)
            if (m_MainWindow != null && m_MainWindow.IsVisible)
                m_MainWindow.Dispose();
        public Result OnStartup(UIControlledApplication application)
            m_MainWindow = null;   // no dialog needed yet; the command will bring it
            thisApp = this;  // static access to this application instance
        public void ShowWindow(UIApplication uiapp)
            // If we do not have a dialog yet, create and show it
            if (m_MainWindow == null )
                RequestHandler handler = new RequestHandler();
                ExternalEvent exEvent = ExternalEvent.Create(handler);
                MyViewModel vmod = new MyViewModel(exEvent,handler);
                m_MainWindow = new MainWindow();
                m_MainWindow.DataContext = vmod;
                m_MainWindow.Show();
I suspect the exception come from thisApp being null, however it cannot have any value at the beginning of initialization.
Any help or suggestion is much appreciated, thanks
I have figured it out, thisApp being null really was the problem, the ExternalApplication class was never invoke, and Revit throw the exception at the ExternalCommand level. I just need to make a new ExternalApplication class instance ,call the ShowWindow method and the program does what I expected:
            try
                new ThisApplication().ShowWindow(commandData.Application);
However, this is exactly how the example in SDK modeless dialog. I wonder why it work there?
reylorente1
I am doing the Revit classes and WPF example? The first M in MVVM, and I want to do it with ExternalEvent.
Notice, that you placed the event in the ViewModel, How did you do it, or if you can give me a tip, to be able to do it, Thanks.
class ViewmodelRevitBridge : BindableBase
        private Dictionary<string, int> _dicWallType;
        private int _selectedWallType;
        private ObservableCollection<string> _listParameters;
        // Declare the Revit model class here.
        // Consequently, create a get-set variable representing this.
        private Model.modelRevitBridge _revitModel;
        public Dictionary<string, int> DicWallType
            get
                return _dicWallType;
            set
                SetProperty(ref _dicWallType, value);
        public int SelectedWallType
            get
                return _selectedWallType;
            set
                SetProperty(ref _selectedWallType, value);
        public ObservableCollection<string> ListParameters
            get
                return _listParameters;
            set
                SetProperty(ref _listParameters, value);
        //  Commands
        // This will be used by the button in the WPF window.
        public ICommand RetrieveParametersValuesCommand
            get
                return new DelegateCommand(RetrieveParametersValuesAction);
        // The get-set variable
        internal Model.modelRevitBridge RevitModel
            get
                return _revitModel;
            set
                _revitModel = value;
        // The action function for RetrieveParametersValuesCommand
        private void RetrieveParametersValuesAction()
            if (SelectedWallType != -1)
                ListParameters = new ObservableCollection<string>(RevitModel.GenerateParametersAndValues(SelectedWallType));
        // Constructor
        public ViewmodelRevitBridge()
