IndependentTag RotationAngle property issue
denisyukJ
denisyukJ
I use RotationAngle property to rotate tag, revit gives me to set the value of the property, but position of tags still the same. Once I select modified tags by rectangle frame it regenerates and rotates. Look at the gif below. Transaction commited so regeneration should be completed automatically, am I correct? Do somebody know how to fix it?
MarryTookMyCoffe
Commit should do document.Regenerate(), from what I remeber. But what is the problem it seems like thy did rotate.
do not worry it only gonna take Autodesk 5 years to fix bug
denisyukJ
Hi, @MarryTookMyCoffe
I need to select elements manually to makes rotation 😞
MarryTookMyCoffe
so what you claim is that when you create tags with rotation property, tag stay with default rotation?
Speed_CAD
I solved it this way:
IndependentTag independentTag = IndependentTag.Create(...);
independentTag.RotationAngle = angle;
// This is the trick
XYZ p = independentTag.TagHeadPosition;
XYZ dx = 1e-6 * activeView.RightDirection;
independentTag.TagHeadPosition = p + dx;
independentTag.TagHeadPosition = p;
doc.Regenerate();
Mauricio Jorquera
