Inconsistent units in Schedules
BenoitE&A
BenoitE&A
Hey,
I create a SharedParameter of type ParameterType.YesNo.
Then I want to populate my new parameter with booleans, I therefore use :
myObject.get_Parameter(myNewParameter.Id).Set()
The problem is : there is no option for booleans for Set() available. Only string, integer, double and ElementId.
Ok I can still use an integer to simulate a boolean...
Benoit
Benoit FAVRE
CEO of etudes & automates
www.etudesetautomates.com/
jeremytammik
Dear Benoit,
Thank you for your query.
Yes, afaik you have to use the integer overload of the Set method.
Sorry about that.
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
