Inconsistent TaskDialog format
mmaso64U7Y
mmaso64U7Y
Steps to reproduce
TaskDialog.Show("Title", "Message.");
var task_dialog = new TaskDialog("Title") { MainContent = "Message." };
task_dialog.Show();
Actual behaviour
The first method (static Show) promts this message:
The second method (non-static Show) prompts this message:
Expected behaviour
Both methods should generate promts with the same format.
Question
Is there a way to achieve the expected behaviour?
jeremy_tammik
This is the intended behaviour. The code you share should not produce the same result. To obtain the first result using the second code statements, replace MainContent by MainInstruction:
mmaso64U7Y
