Includes set and save in Publish Setting
khagesh_mahajan
khagesh_mahajan
For including set in publish setting, I am able to create new set and added the views to that particular set.
Here is the code for creating and adding views to it.
Document doc = this.ActiveUIDocument.Document;
			List<Element> views = new FilteredElementCollector(doc).OfClass(typeof(View)).WhereElementIsNotElementType().Where(v => v.Name.Contains("Analytical")).ToList();
			ViewSet myViewSet = new ViewSet();
			foreach (View v in views) {
				myViewSet.Insert(v);
			PrintManager printMgr = doc.PrintManager;
			printMgr.PrintRange = Autodesk.Revit.DB.PrintRange.Select;
			ViewSheetSetting viewSheetSetting = printMgr.ViewSheetSetting;
			viewSheetSetting.CurrentViewSheetSet.Views = myViewSet;
			using (Transaction transaction = new Transaction(doc, "NewSheetSet"))
				transaction.Start();
				try
					viewSheetSetting.SaveAs("AnalyticalModelSet");
				catch (Exception ex)
					TaskDialog.Show("Error", ex.Message);
				transaction.Commit();
Here is the screenshot after code run.
Here how could I 'include' this set (here named AnalyticalModelSet) and then 'save & close' using the API?
jeremy_tammik
You can read about C4R Publish View to Cloud API and see how add your vote to the Revit Idea Station wishlist item here:
