in revit, how to set beam endpoint to not allow connect?
in revit, how to set beam endpoint to not allow connect? thinks!
matthew_taylor
Here's a link to the function: DisallowJoinAtEnd
Sometimes it's just knowing what word to search for! (For clues on this, ask yourself what Revit calls something when using the standard interface.)
Good luck.
-Matt
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
