Importing json into Revit using the API:
J450NP13
Advisor Advisor
Message 1 of 23
J450NP13
So I have the CustomExporterAdnMeshJson solution.  I got it working in 2021.
Is there a way to import json the same way?  if so is there an example.
Replies (22)
Message 21 of 23
J450NP13
@mastjaso  are you using it to send json to Revit?
Message 22 of 23
mastjaso
Honestly, no idea if it will help in your case. I use often use it to send JSON data around between processes but I'm not typically sending geometry data nor running into json length issues so I don't actually know if it will help or not. It's just a relatively popular and often better JSON serializer/deserializer than .NET's built in one, so it may be worth trying to see if you run into the same issues, but I have no way of knowing one way or another.
Message 23 of 23
J450NP13
@mastjaso
I’ll try it.
I figured out why it wasn’t working.  It’s because I had pts that we’re sharing the same location.
Instead of mesh data I am going to just pass their dimensions.
