Importing an excel sheet using c#
How can one import an excel file to revit and create a schedule from it. Please include source code.
jeremytammik
Look at the Revit SDK samples and search globally for 'excel'. Some of them import data from excel spreadsheets. I don't know whether you can create a schedule that way, though. Can you do that manually through the user interface at all?
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
So as you have suggested, I tried one of the samples in SDK, "PointsFromExcel - create reference points based on XYZ data in an Excel file". to see how does it work.
I attached the screenshots of what I got in VS and Revit, after trying to implement the code. My question is when I was showing and reading an excel file in C# earlier, other than my main Cs file, I had to create a Form File ( graphics ) and in that file, I entered the path of my excel file. But for Revit, I don't know where is the exact location that I can enter the path of my excel file location. Could you please look at the attached pictures.
Another screenshot
aignatovich
Hi!
I didn't find PointsFromExcel in samples folder in Revit SDK
However, exception message it is clear: all classes, that implement IExternalCommand interface must have Transaction attribute, for example, I opened the first sdk sample:
Revit SDK 2017\Software Development Kit\Samples\AddSpaceAndZone\CS\Command.cs
The firs attribute of Command class is:
[Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
two others (Regeneration and Journaling) are optional
Sincerely, Alexander
for (i = 0; i <= ds.Tables[0].Rows.Count - 1; i++)
    for (j = 0; j <= ds.Tables[0].Columns.Count - 1; j++)
        data = ds.Tables[0].Rows[i].ItemArray[j].ToString();
        xlWorkSheet.Cells[i + 1, j + 1] = data;
Full source...import to excel file
Use this code
using System;
using System.Data;
using System.Data.OleDb;
using System.IO;
using System.Windows.Forms;
namespace WindowsFormsApplication3
    public partial class Form2 : Form
        public Form2()
            InitializeComponent();
        private void button1_Click(object sender, EventArgs e)
            var dt = new DataTable();
            var fileName = Path.Combine(AppDomain.CurrentDomain.BaseDirectory, "File1.xlsx");
            var query = "SELECT F1 As A, F2 As B, F3 As C FROM [Sheet1$]";
            using (OleDbConnection cn = new OleDbConnection { ConnectionString = ConnectionString(fileName, "No") })
                using (OleDbCommand cmd = new OleDbCommand { CommandText = query, Connection = cn })
                    cn.Open();
                    OleDbDataReader dr = cmd.ExecuteReader();
                    dt.Load(dr);
            if (dt.Rows.Count >1)
                // remove header
                dt.Rows[0].Delete();
            dt.AcceptChanges();
            Console.WriteLine();
        public string ConnectionString(string FileName, string Header)
            OleDbConnectionStringBuilder Builder = new OleDbConnectionStringBuilder();
            if (Path.GetExtension(FileName).ToUpper() == ".XLS")
                Builder.Provider = "Microsoft.Jet.OLEDB.4.0";
                Builder.Add("Extended Properties", string.Format("Excel 8.0;IMEX=1;HDR={0};", Header));
            else
                Builder.Provider = "Microsoft.ACE.OLEDB.12.0";
                Builder.Add("Extended Properties", string.Format("Excel 12.0;IMEX=1;HDR={0};", Header));
            Builder.DataSource = FileName;
            return Builder.ConnectionString;
or try to ZetExcel.com this would help you.
