Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Import floor or wall and edit its thickness
1 REPLY 1
355 Views, 1 Reply
Hi!
Im developing an add-on for Revit and I want to preload an object directly when people install my add-on and further on, edit the thickness of said wall or floor, accodring to a value that the user inputs. So I was just wondering if there is a way to do this, to preload an object and to edit the thickness of it. Any help is extremly appreciated, thanks in advance! (:
1 REPLY 1
Moustafa_K
you can preload objects if they are family types (Family instances => Chairs, window, doors..etc) ... but you can't pre load Builtin Types (Walls, floors, ceiling) however, you can have a project template (*.rte) containing those objects that you want to preload, and then you can manipulate with the parameters you need (such as thickness)
I hope this helps
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
