Import data from excel to revit
elango_saramani
elango_saramani
I have written a code for importing parameter value for pipe project parameter.The datas are reading from excel but when i run the file data is empty in revit Please let me if there is anything i missed up in the code
using System;
using System.Collections.Generic;
using System.IO;
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using OfficeOpenXml; // Ensure EPPlus namespace is used
namespace RevitExcelAddIn
public class UpdatePipeParametersCommand : IExternalCommand
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
Document doc = commandData.Application.ActiveUIDocument.Document;
string filePath = @"C:\Users\xxxxx\xxx)\Pipe_Schedule1.xlsx";
var familyData = ReadExcelFile(filePath);
foreach (var data in familyData)
try
UpdateParametersInRevit(doc, data);
catch (Exception ex)
message = $"An error occurred while updating parameters: {ex.Message}";
return Result.Failed;
return Result.Succeeded;
static List<FamilyData> ReadExcelFile(string filePath)
var data = new List<FamilyData>();
FileInfo fileInfo = new FileInfo(filePath);
using (var package = new ExcelPackage(fileInfo))
ExcelWorksheet worksheet = package.Workbook.Worksheets[0];
for (int row = 2; row <= worksheet.Dimension.End.Row; row++)
var familyType = worksheet.Cells[row, 1].Text;
var familyName = worksheet.Cells[row, 2].Text;
var diameter = worksheet.Cells[row, 3].Text;
var parameters = new Dictionary<string, string>
{ "ComponentGroup", worksheet.Cells[row, 4].Text },
{ "ComponentGroupDescription", worksheet.Cells[row, 5].Text },
// Add remaining parameters
data.Add(new FamilyData
FamilyType = familyType,
FamilyName = familyName,
Diameter = diameter,
Parameters = parameters
return data;
static void UpdateParametersInRevit(Document doc, FamilyData data)
var collector = new FilteredElementCollector(doc)
.OfCategory(BuiltInCategory.OST_PipeCurves)
.WhereElementIsNotElementType();
foreach (FamilyInstance instance in collector)
if (instance.Symbol.Family.Name == data.FamilyName && instance.Symbol.Name == data.FamilyType)
using (Transaction trans = new Transaction(doc, "Update Pipe Parameters"))
trans.Start();
foreach (var kvp in data.Parameters)
Parameter param = instance.LookupParameter(kvp.Key);
if (param != null)
try
if (param.StorageType == StorageType.String)
param.Set(kvp.Value);
else if (param.StorageType == StorageType.Double)
if (double.TryParse(kvp.Value, out double doubleValue))
param.Set(doubleValue);
else
throw new FormatException($"Cannot convert '{kvp.Value}' to Double.");
else if (param.StorageType == StorageType.Integer)
if (int.TryParse(kvp.Value, out int intValue))
param.Set(intValue);
else
throw new FormatException($"Cannot convert '{kvp.Value}' to Integer.");
else
throw new NotSupportedException($"Parameter storage type '{param.StorageType}' is not supported.");
TaskDialog.Show("Parameter Update Error", $"Error updating parameter '{kvp.Key}': {ex.Message}");
trans.Commit();
class FamilyData
public string FamilyType { get; set; }
public string FamilyName { get; set; }
public string Diameter { get; set; }
public Dictionary<string, string> Parameters { get; set; }
reylorente1
hello, shouldn't I put MepCurve or Pipe when you run the foreach?
foreach (Pipe instance in collector)
if (instance.Name == data.FamilyName && instance.PipeType.Name == data.FamilyType)
elango_saramani
Updated cod but still not working
trans.Start();
reylorente1
And he doesn't ask for your license?
Because when I use Epplus, it always asks me for a license.
Here I show you part of a code...
public static DataTable Data { get; set; }
#region DataReadExcel
/// <summary>
/// Insertar un Excel a DataGrid
/// </summary>
/// <returns></returns>
public static DataTable ReadExcel()
string filePath = @"E:\000000 - Carpeta organizada\Agrupar A\A-Excel\Excel\LE.xlsx";
ExcelPackage.LicenseContext = LicenseContext.NonCommercial;
using (ExcelPackage excelPackage = new ExcelPackage(new FileInfo(filePath)))
Data = ExcelPackageToDataTable(excelPackage);
return Data;
#endregion
Mohamed_Arshad
Hi @elango_saramani
   I have seen few error in your code. As @reylorente1 mentioned you have to implement the License Context for Epplus. I have updated your code little bit. Kindly check it.
Reference Code (TransactionAttribute Missing)
    [Transaction(TransactionMode.Manual)] ///Missing Transaction Attribute
                try
LicenseContext Missing
            return data;
My Suggestion :
    Use Element and ElementType while dealing with Parameters don't convert to particular type. We can able to access Parameter directly from the Element class.
Reference Code
        foreach (Element element in collector) ///Convert FamilyInstance to Element
            ///Use Element Type
            ElementType elementType= doc.GetElement(element.GetTypeId()) as ElementType;
            if (elementType.Name == data.FamilyName && elementType.FamilyName == data.FamilyType)
                    trans.Start();
                        Parameter param = element.LookupParameter(kvp.Key);
                        if (param != null)
                            try
                                    else
                                    else
                                else
                    trans.Commit();
Hope this will Helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
Mohamed_Arshad
HI @elango_saramani
Here is the code correction below,
using System;
using System.IO;
using Autodesk.Revit.Attributes; // Ensure EPPlus namespace is used
                try
            return data;
                ///Use Element Type
                        trans.Start();
                            if (param != null)
                                try
                                        else
                                        else
                                    else
                        trans.Commit();
    class FamilyData
Mohamed Arshad K
