IFCExport, Use IFC Export setting from the alternate UI Setup name.
Hello everyone.
I try to make a IFC Exporter to our company, where I use the settings from alternate UI Setup name.
I use the IFCExportOptions and the doc.Export(), But how I can use the setting from alternate UI Setup name?
Is there someone who can explain my hvorden I do it.
Thank you for your time.
Best regards
AWPE
rosalesduquej
hi Awpe,
I partially understand what you are trying to do, Could you elaborate a bit more on it please. Maybe a couple of screenshots will help better to understand your desired workflow. Thank you for your collaboration and patiance.
Cheers,
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
Hi rosalesduquej.
Thank you for your message.
When I use the IFCExportOptions class, you only have access to this options: ExportBaseQuantities, FamilyMappingFile, FileVersion, FilterViewId, IsValidObject, SpaceBoundaryLevel and WallAndColumnSplitting.
In our company we have installed the alternate IFC exporter v 16.4.0
https://apps.autodesk.com/RVT/en/Detail/Index?id=3754730560173591798&appLang=en&os=Win32_64
In this IFC Exporter, is there lot of options you does not have access to from the IFCExportOptions class.
I want to make a IFC Export where i us all the options from a "setup Name" in the alternate IFC exporter.
It is possible to us the "Setup name" with the doc.Export()???.
E.g
doc.Export("folder", "Name", "Setup name");
Or how can i make a IFC Export with all the options?
Best regards
AWPE
