IFC4 Export: Triangulate / Tesselale everything
Hello everybody
I need to know if it's possible and if yes, how to export Revit-Models into an IFC4-File with every geometry tessellated/triangulated, so that the IFC4-File contains for every object the vertices and faces (and may normals). The structure of IfcTriangulatedFaceSet ist perfect for what I need.
I want to take the vertices and faces of the objekt to process them further.
At the moment I can only export to IFC4 and the file contains too many complex information like ExtrudedAreSolid, RectangleProfileDef, BReps, Splines etc.
So to imagine a concrete case: If someone creates a Wall with a 90° Corner by using 3 Points, a spline and then he Extrudes this Wall. The exportet IFC4-File contains this comlplex information but no vertices of the wall's faces. It would be nice to export the Modell and to get the vertices-coordinates.
Greeting
jeremytammik
Yes, you can easily obtain tessellated output from Revit containing all geometry and with no additional BIM data or structure attached.
Simply drop the IFC requirement and use a custom exporter:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.1
With the custom exporter vertices in hand, you can easily generate IfcTriangulatedFaceSet objects for all the elements.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
