IFC Parameters
IFC Parameters
alicia2S8RB
Observer Observer
IFC Parameters
alicia2S8RB
Observer
Observer
Hi
I would like to know if it is possible export the following situation:
I want a property, for example, "4.8 Concrete class", to have its value set to the "Standard" parameter, except if the "concrete quality" parameter is filled in.
If it is possible, and if someone can explain it to me, I would appreciate it.
TripleM-Dev.net
By property you mean Parameter?
Sure you can eval the parameters HasValue, if False it has no value and fill in a default value of you're choice.
If it's a Text parameter you have to make a choice if it is a empty text, does it then also get a default value.
See: https://www.revitapidocs.com/2023/2761a43b-3199-bbbb-6e6d-8ffd82febdec.htm
If you don't know how to retrieve a parameter, i suggest to search this forum or download the SDK. lots of samples
- Michel
