Identifying the light source geometry
Hi all,
When I call get_geometry on a Lighting Fixture element, is there a way to check if the GeometryObject is the Light Source geometry? I am trying to identify it so I don't have to export it.
Mitch
jeremytammik
Yes, there is.
A sample light fixture geometry includes five solids. One of them is empty, two others represent the light fixture geometry, and the last two represent the light source.
You can differentiate between them by checking the solid's GraphicsStyleId property:
https://www.revitapidocs.com/2020/4103f148-957e-3f44-9ccd-a5ed6702c689.htm
Here are the details of snooping the element and its geometry:
Id=566552; Class=FamilyInstance; Category=Lighting Fixtures; Name=120V; UniqueId=bc43ed2e-7e23-4f0e-9588-ab3c43f3d388-0008a518
Manage > Select by ID
RevitLookup > Snoop current selection
Geometry > View = null > Coarse
GetInstanceGeometry --> five solids
1. solid: zero volume, empty
2. solid: GraphicsStyleId null, volume 0.101...
3. solid: GraphicsStyleId null, volume 0.0189...
4. solid: GraphicsStyleId Light Source 88699, volume 8.97...
5. solid: GraphicsStyleId Light Source 88699, volume 8.97...
Here are some snapshots illustrating the snooping process and the results obtained:
Snooping with RevitLookupSnooping with RevitLookup
Coarse view nullCoarse view null
Light sourceLight source
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
