ID I want to write in the URL type properties field
Message 1 of 1
Hello I would like to be able to write in the URL type properties field and put inside the Id of the type of family type.Id
If you can help me?
import clr
import System
clr.AddReference('RevitAPI'
clr.AddReference('RevitAPIUI'
from Autodesk.Revit.DB import *
app = __revit__.Application
uidoc = __revit__.ActiveUIDocument
doc = __revit__.ActiveUIDocument.Document
t = Transaction(doc, 'Write parameters.')
t.Start()
cl_views = FilteredElementCollector(doc)
vptypes = cl_views.OfClass( ElementType ).ToElements()
#__window__.Close()
for type in vptypes:
        print('ID: {0} FAMILLE: {1} TYPE: {2}'.format(
        str(type.Id).ljust(10),
        ElementType.FamilyName.GetValue(type).ljust(70),
        Element.Name.GetValue(type).ljust(70),
Thanks much for your help
Patrick
Thanck
Replies (0)
