I want to use revit own control in my plugin,is there any method to achieve this
I think the revit own control is very beautiful,I want use it in my plugin,how can do to achieve this.
thank you  very mach!
jeremytammik
The Revit UI Labs section of AdnRevitApiLabsXtra shows just about all you can achieve using the Revit UI API:
https://github.com/jeremytammik/AdnRevitApiLabsXtra
I am afraid it may not cover the widget you want.
Obviously, the entire Revit UI has been built using the underlying Windows API, so you can theoretically rebuilt your own version of every single Revit UI widget from scratch...
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
thank you very much!
