Hi.
First, when the button located on the Ribbon is clicked, a UI should appear. Then, I want to make it so that when another button is clicked in the UI, a function I wrote is executed. I still lack understanding, so I appreciate it if you can explain it comprehensively.
- What should the UI be created with? WPF?
- Is it possible for the Add-in to read and handle an external text file?
- Where should the source code for the button's execution be written?
