I want to automatically open the 3d view of my model
oguzkomcu
oguzkomcu
I am very new to developing Revit Api. Thank you for helping me with many of my questions here.
I have a problem . I need to automatically open the 3d view of my model and have the export process done automatically. I thought I had solved this before, but I was wrong. Then it gave an error. I probably need to use these classes "ApplicationInitialized" , "DocumentOpened" but I don't understand how to use them. Can you help me ?
jeremy_tammik
ApplicationInitialized notifies you that Revit has started up and completed initialisation:
https://www.revitapidocs.com/2022/f35ba9fc-0b6b-4284-60eb-91788761127c.htm
DocumentOpened is called when a new document is opened:
https://www.revitapidocs.com/2022/7e5bc7a1-0475-b2ec-0aec-c410015737fe.htm
Both require you to implement an event handler in which you can perform your task.
In fact, the entire Revit API is event-driven, and all Revit API access is performed within event handlers of various kinds..
I suggest that you search the Revit SDK, this forum, The Building coder and the Internet in general for samples on using them.
Good luck and have fun!
