I can't find sub class parameter in ThermalAsset that i created
Message 1 of 9
Hello ,
I try to create a new ThermalAsset and i try to bindit to my matreial but when i want to set value to subclass parameters he can't find this property on this asset this my code can you help me please ?
 ThermalAsset thermal = new ThermalAsset(matName.TrimEnd(), ThermalMaterialType.Solid)
                                                TransmitsLight = false,
                                                Permeability = permeabilite,
                                                Porosity = materiallocale.thermal_Porosite,
                                                Reflectivity = materiallocale.thermal_Reflectivite,
                                                ElectricalResistivity = electrique,
                                                SpecificHeat = heat,
                                                Density = density,
                                                ThermalConductivity = condivite,
                                                Emissivity = materiallocale.thermal_emissivite,
                                            pst.get_Parameter(BuiltInParameter.PHY_MATERIAL_PARAM_SUBCLASS).Set(materiallocale.thermal_subclass);
                                            pst.get_Parameter(BuiltInParameter.PROPERTY_SET_KEYWORDS).Set(materiallocale.keynote);
                                            pst.get_Parameter(BuiltInParameter.MATERIAL_ASSET_PARAM_SOURCE).Set(materiallocale.thermal_source);
Replies (8)
Message 2 of 9
MarryTookMyCoffe
If you what to set up thermalAsset to material, yuo have to use:
Snippet
material.SetMaterialAspectByPropertySet(MaterialAspect.Thermal, your asset ID )
 for more info you can look in this post:
https://forums.autodesk.com/t5/revit-api-forum/create-new-material-and-add-new-physical-and-thermal-...
do not worry it only gonna take Autodesk 5 years to fix bug
Message 3 of 9
Actually my problem is i can't map sub class parameter with my new assetand it's not how to bind it to my material
this instrcution won't because it can't find the subclass property on my new asset
 myMaterial.get_Parameter(BuiltInParameter.PHY_MATERIAL_PARAM_SUBCLASS).Set(materiallocale.thermal_subclass);
Snippet
Message 4 of 9
MarryTookMyCoffe
you need to give a more info, there is no way to test anything on your code.
do you use a RevitLookup?
Message 5 of 9
THANK YOU for your help more details this is my test code i duplacte material i create new thermal asset during giving a value for the property sub class it will crash
  string matName = "Test Material";
  Material myMaterial = null;
                                Material materialCSI = new FilteredElementCollector(doc).OfClass(typeof(Material)).Cast<Material>().Where(es => es.Name == matName.TrimEnd()).FirstOrDefault<Material>();
                                if (materialCSI == null)
                                            materialCSI = new FilteredElementCollector(doc).OfClass(typeof(Material)).Cast<Material>().FirstOrDefault<Material>();
                                            // Duplicate material
                                            myMaterial = materialCSI.Duplicate(matName.TrimEnd());
                                        using (Transaction tx = new Transaction(doc))
                                            tx.Start("Add Materials");
                                                Permeability = 1,
                                                Porosity = 1,
                                                Reflectivity = 1,
                                                ElectricalResistivity = 1,
                                                SpecificHeat = 1,
                                                Density = 1,
                                                ThermalConductivity = 1,
                                                Emissivity = 1,
                                            PropertySetElement pst = PropertySetElement.Create(doc, thermal);
                                            myMaterial.get_Parameter(BuiltInParameter.PHY_MATERIAL_PARAM_SUBCLASS).Set("sub class thermal");
                                            pst.get_Parameter(BuiltInParameter.PROPERTY_SET_KEYWORDS).Set("key note ");
                                            myMaterial.SetMaterialAspectByPropertySet(MaterialAspect.Thermal, pst.Id);
                                            //Assign the property set to the material.
                                            PropertySetElement pse = PropertySetElement.Create(doc, strucAsset);
                                            pse.get_Parameter(BuiltInParameter.PHY_MATERIAL_PARAM_SUBCLASS).Set("sub class physic");
                                            myMaterial.SetMaterialAspectByPropertySet(MaterialAspect.Structural, pse.Id);
                                            tx.Commit();
Message 6 of 9
MarryTookMyCoffe
change :
to:
pst.get_Parameter(BuiltInParameter.PHY_MATERIAL_PARAM_SUBCLASS).Set("sub class thermal");
Message 7 of 9
I tried that it didn't work 😞
Message 8 of 9
MarryTookMyCoffe
i did simple macro in revit and all propertysetelement I chose change. try first changing parameter is propertySetElement and then add it to a material
		public void material()
						Document doc = this.Application.ActiveUIDocument.Document;
			FilteredElementCollector fec = new FilteredElementCollector(doc).OfClass(typeof(PropertySetElement));
			List<PropertySetElement> list = fec.Cast<PropertySetElement>().Where(es => es.Name=="Air").ToList();
			Transaction trans = new Transaction(doc);
			trans.Start("testr");
			foreach (PropertySetElement element in list) {
				element.get_Parameter(BuiltInParameter.PHY_MATERIAL_PARAM_SUBCLASS).Set("zmieniłem");
			trans.Commit();
Message 9 of 9
Hello! By any chance did you got to solve this issue? I am facing the exact same problem.
Best Regards,
JMGP
