I can't download the Worksharing Monitor
Hi everyone,
as mentioned here, I tried the link given in the description. But it only leads me to my Autodesk Account Profile page. If I use the search function, I can't find the Worksharing Monitor tool either. Even in the Exchange Apps I'm not able to.
So... where can I find the latest version for the Revit Worksharing Monitor to download?
Thanks very much 4 help!! 🙂
jeremytammik
Dear Sts,
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try the Revit product support discussion forum instead for that.
I hope this clarifies.
Thank you for your understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Hi Jeremy, thanks, but there is no such forum. There are only Revit Architecture, Revit MEP, Revit Structure and Revit API. Therefore the last was the most appropriate solution for me. Can you please tell me where I can find the forum you suggested? Thanks! 🙂
jeremytammik
Dear Sts,
Revit API is for programming, and all the others are not.
Therefore, all the others are appropriate, and Revit API is not.
I would post to the largest and most general one, which is presumably the architectural one.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
