Hwo can I create a standalone wallsweep?
I can find a sample what can create a wallsweep in a wall type,
But the walltype was changed,I want to create a standalone wallsweep what can not change the walltype,How can I do?
I can find a little information from JEREMY TAMMIK`s blog.
The Building Coder: Many Issues Resolved
Standalone wall sweeps and reveals may be constructed using the static method Create().
But In the SDK, the mothod is
public static WallSweep Create( Wall wall, ElementId wallSweepType, WallSweepInfo wallSweepInfo)
Because wallSweepType is the ElementId type,I don't know How to use the method.
Please help me.Thank you;
gopinath.taget
I have enquired with the engineering team about this. I will get back to you as soon as I have some relevant information.
Thanks for your patience.
Best Regards,
Gopinath
gopinath.taget
My engineering colleagues got back to me with this code snippet to determine the WallSweepTypeId:
        private ElementId GetSweepOrRevealTypeId(WallSweepType sweepType)
            FilteredElementCollector wallSweeps = new FilteredElementCollector(RevitDoc);
            wallSweeps.OfClass(typeof(WallSweep));
            Func<WallSweep, bool> IsUnfixedSweep = sweep => !sweep.GetWallSweepInfo().IsFixed && sweep.GetWallSweepInfo().WallSweepType == sweepType;
            return wallSweeps.OfType<WallSweep>().FirstOrDefault<WallSweep>(IsUnfixedSweep).GetTypeId();
        WallSweep sweep = WallSweep.Create(wall, GetSweepOrRevealTypeId(WallSweepType.Sweep), sweepInfo);
Another approach to determining the WallSweepType is:
FilteredElementCollector collector = new FilteredElementCollector(this.Document);
collector.OfCategory(BuiltInCategory.OST_Cornices);
ElementType wallSweepType = collector.FirstElement() as ElementType;
Hope this helps.
Gopinath
This no problem to run this Code. Thank you very much.
