Human Readable Strings
Dale.Bartlett
Dale.Bartlett
I stumbled upon this gem when researching a method to reverse PascalCasing to a sentence string. I trust someone finds it as helpful as I did.
https://github.com/Humanizr/Humanizer
Credit for the following answer goes to:
Banketeshvar Narayan
https://stackoverflow.com/questions/323314/best-way-to-convert-pascal-case-to-a-sentence
Humanizer is a Portable Class Library that meets all your .NET needs for manipulating and displaying strings, enums, dates, times, timespans, numbers and quantities.
"PascalCaseInputStringIsTurnedIntoSentence".Humanize() => "Pascal case input string is turned into sentence"
"Underscored_input_string_is_turned_into_sentence".Humanize() => "Underscored input string is turned into sentence"
"Can_return_title_Case".Humanize(LetterCasing.Title) => "Can Return Title Case"
"CanReturnLowerCase".Humanize(LetterCasing.LowerCase) => "can return lower case"
Complete code :
using Humanizer;
using static System.Console;
namespace HumanizerConsoleApp
   class Program
       static void Main(string[] args)
           WriteLine("AwaitingFeedback".Humanize());
          WriteLine("PascalCaseInputStringIsTurnedIntoSentence".Humanize());
           WriteLine("Underscored_input_string_is_turned_into_sentence".Humanize());
           WriteLine("Can_return_title_Case".Humanize(LetterCasing.Title));
           WriteLine("CanReturnLowerCase".Humanize(LetterCasing.LowerCase));
Output
Awaiting feedback
Underscored input string is turned into sentence Can Return Title Case
______________
Yes, I'm Satoshi.
jeremytammik
Dear Dale,
Thank you very much for your useful link.
Reading the documentation, I must agree:
Wow, Humanizer sure is a really powerful and comprehensive package!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
