How to use the addColumnAttachement Method
zrodgersTSSSU
zrodgersTSSSU
Im looking for an example of how to use the addColumnAttachment Method. Having trouble understanding how to implement it. Please let me know if you have any examples.
https://www.revitapidocs.com/2015/27944249-fe98-f6ef-ba85-6408535b2d0b.htm
jeremy_tammik
I asked the development team for you.
zrodgersTSSSU
Any response from the dev. team?
so-chong
Here i have a very basic and simple macro that demonstrate the use of the addColumnAttachment Method.
public void AttachColunm()
    UIDocument uidoc = this.ActiveUIDocument;
    Document doc = this.ActiveUIDocument.Document;
    using (Transaction t = new Transaction(doc, "attach column to beam"))
	t.Start();
    Reference myRef = uidoc.Selection.PickObject(ObjectType.Element, "Select column");
	FamilyInstance column = doc.GetElement(myRef) as FamilyInstance;
    Reference myRef2= uidoc.Selection.PickObject(ObjectType.Element, "Select beam");
	FamilyInstance targetBeam = doc.GetElement(myRef2) as FamilyInstance;
	ColumnAttachment.AddColumnAttachment(doc, column, targetBeam, 1, ColumnAttachmentCutStyle.None,
	                                     ColumnAttachmentJustification.Minimum, 0);
	t.Commit();
First select a column and then select a beam.
It's similar to the Revit end user interface 'Attach Top/Base' button from the Modify | Structural Columns Ribbon tab.
I hope this will help you for better understanding and how to implement it.
zrodgersTSSSU
I totally over complicated it!! thank you so much @so-chong & @jeremy_tammik  for your responses!
@so-chong That worked like a charm!
