How to use MarkUp(Where i can draw, write on revit files) in Revit.
I followed official documentation of Autodesk.
I am able to view revit file using token and documentid.
Now i want to write something on that 3D image.
But not able to find any solution.
Please help me.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage, or end-user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not-for/td-p/5607765
I hope this clarifies.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Please note this forum is dedicated for Revit API programming questions.
Are you doing the markup via Revit API?
Do you want to create the markup via Revit programming?
Your question on using markup seems to be more of a Revit UI(Product usage) question than a Revit API question.
There is a separate forum dedicated for Revit product usage questions
https://forums.autodesk.com/t5/revit-architecture-forum/bd-p/133
You will find a better answer for Revit product usage non-API question in the Revit Architecture forum than the Revit API forum.
Naveen Kumar T
