How to use API to open Revit Server file and reload working set button available?
464905795
Message 1 of 10
464905795
As the title says,I open Revit Server File by api,however the reload workset button isn't available.
 private void OpenDetached(UIApplication app, ModelPath modelPath)
            OpenOptions opt = new OpenOptions();
            opt.DetachFromCentralOption = DetachFromCentralOption.DoNotDetach;
            app.OpenAndActivateDocument(modelPath, opt, false);
Replies (9)
Message 2 of 10
jeremy_tammik
Thank you for your query and sorry we were unable to resolve it in the previous thread on this. I asked the development team for you.
Message 3 of 10
464905795
Hello Jeremy,Thank you for your reply,this problem is very important for my product,I look forward to receiving your solution as soon as possible。
Message 4 of 10
251912960
Has the problem been solved? I also want to know the answer, hope help, thank you!
Message 5 of 10
jeremy_tammik
Yes, sorry, no reply received yet. I re-prompted the development team for advice.
Message 6 of 10
jeremy_tammik
The development team suggest:
Something to test:
1) Open it
2) Get the local and central path
Assuming the central still points at the server and not another location, proceed to 3 and 4:
3) Close it
4) Open the local path
That may push things in the right direction, though the added time isn’t ideal. If it doesn’t point at the server, they may need to make another call to open the document.
I hope this helps.
Message 7 of 10
251912960
The problem has been solved,Thank you very much.
Message 8 of 10
jeremy_tammik
Glads to hear that. Thank you for your appreciation.
Can you share with us exactly how you solved it, please, for others who may encounter the same issue?
Message 9 of 10
251912960
Reference code:
ModelPath toOpenPath = ModelPathUtils.ConvertUserVisiblePathToModelPath(localPath);
WorksharingUtils.CreateNewLocal(modelPath, toOpenPath );
app.OpenAndActivateDocument(toOpenPath , opt, false);
Message 10 of 10
jeremy_tammik
The development team explain: This is by design. The central model was opened directly when using the  OpenDetached() method because it uses the  central model's ModelPath. So, ReloadLatest cannot be used in this case; there is no related stuff to reload, because central is always latest when you're on it, and all other clients cannot work with central when the central is opened directly. This is not a recommended way to use the worksharing feature. The correct way would be to create a new local file based on central. Then, it should work correctly. File-based worksharing should have the same behaviour.
