How to Unregister Updater?
felix.hopmann
felix.hopmann
I am writing an AddIn which adds a custom View and uses Document-bound Updaters to manage some information in it. These updaters are non-optional as long as there are custom views in the document, however, they aren't needed as soon as all AddIn-created views are deleted.
To achieve this, I tried:
I only register the updater upon creation of custom views or when I find some upon loading. (This works)
Upon saving, I test for AddIn-created views, if there aren't any left, I do
Autodesk.Revit.DB.UpdaterRegistry.UnregisterUpdater(id, doc);
which appears to succeed, as the Updater isn't called anymore and repeating calls to this fail with the message that the updater doesn't exist anymore.
However, if I try to load that document, I get the warning that the Updaters are missing.
How can I tell Revit that a previously used Updater won't be needed anymore?
EDIT: I know that I could just always register the updater, but this won't help users who don't have my AddIn.
EDIT2: Btw, I'm using Revit2017, if that makes any difference.
tshunau
I believed the only way to do it is actually to detach the model from central and save as a new central file.  Let me know if that works for you
Tak Au,
FAIR59
On registering the Updater you can specify that the updater is Optional.
http://www.revitapidocs.com/2016/edffd44c-2511-c9ee-f330-5cd77414d0e9.htm
felix.hopmann
I know that I can do this, and this is what I am currently doing, however, as long as AddIn-created views exist in the document, I want the warning to show up, so, basically, I want to repeatedly switch between optional and non-optional.
Meanwhile, I tried updating the IsOptional property of the Updater in the Saving and SavingAs events, unfortunately to no success, the first value set seems to be persistent.
FAIR59
I suppose you've used UpdaterRegistry.SetIsUpdaterOptional() to change the IsOptional property.
felix.hopmann
Yes. Immediately after creation it works, later apparently it doesn't. However, it doesn't throw errors either.
felix.hopmann
Seems to be the same issue as in https://forums.autodesk.com/t5/revit-api-forum/unable-to-disable-warning-for-missing-third-party-upd... except for that if it is set upon creation, it works. However, I am always testing with new documents, i.e. on re-creation it might behave like in that other thread.
