How to unlock lock inside ceiling sketch to wall?
I would like to unlock the ceiling sketch that is locked to walls in a project.
I would probably collect all ceilings, access all their sketch lines and then unlock every padlock to a wall or just all padlocks. is this possible i cant find the properties to do this?
jeremytammik
If the elements are pinned you can use the Element.Pinned property.
If they are constrained, the constraint is a separate element that you might be able to delete.
Jeremy Tammik
Developer Technical Services
The Building Coder
jlpgy
Hi @jeremytammik :
I would like to ask a further question:
How can I access the constrain object?
For example, in Family document:
In family doc, there are a lot of "locks". It it possible for API to obtain this object?
Sometimes I want to know which two objects are constrained by this contrain, or I want to programmatically delete it.
单身狗;代码狗;健身狗;jolinpiggy@hotmail.com
jeremytammik
Dear @jlpgy ,
Have you installed and tested RevitLookup?
https://github.com/jeremytammik/RevitLookup
If not, I would suggest doing so right now.
That should enable you to immediately answer your question yourself.
Good luck and have fun!
Jeremy
Jeremy Tammik
The Building Coder
jlpgy
I found it, it's a <Dimension> object, can be accessed by Snoop DB.
