Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
How to understand the BoundingBoxUV of face
2 REPLIES 2
1217 Views, 2 Replies
Hi all!
I am recently doing something with AVF, and have some problems with the BoundingBoxUV of face. I use following codes to achieve the feature points of the bottom-left corner area of the face,  but the result shows that the feature points refer to the upper-right corner area.
 BoundingBoxUV boundingBoxUV = face.GetBoundingBox();
UV min = boundingBoxUV.Min;
double midU = (boundingBoxUV.Max.U + boundingBoxUV.Min.U) / 2;
double midV = (boundingBoxUV.Max.V + boundingBoxUV.Min.V) / 2;
UV mid = new UV(midU, midV);
I'm confused about this result! anyone can help me? Thanks in advance!
2 REPLIES 2
jeremytammik
in reply to: 1120415118
You need to know in which XYZ direction in 3D space the UV vector components U and V are pointing.
You can find out by projecting a XYZ point onto the face surface and seeing where it ends up:
https://www.revitapidocs.com/2020/802cc09b-d0a4-dfc5-8ca1-e8c5e8cd4ced.htm
  public void Project(
    XYZ point,
    out UV uv,
    out double distance
There is probably some more direct way to query either the face or its underlying surface for the U and V directions in 3D space.
Please find out and let us know.
Thank you!
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
in reply to: jeremytammik
Thanks for your replay, Jeremy Tammik.
Forgive my stupidity, I don't understand your method, but it inspired me to think of another way. I use Dynamo to query the U and V directions of the face, and I am glad to share it.
