How to Triangulate() Not-Planar Faces
ankofl
ankofl
I have a method that creates a triangulated solid mesh based on Solid, but it only works with PlanarFace.
public static bool CreateMesh(this Solid solid, out List<XYZ> listVectors, out List<Tri> listTri)
	double k = UnitUtils.ConvertFromInternalUnits(1, UnitTypeId.Meters);
	listVectors = [];
	listTri = [];
	bool allPlanar = true;
	int indV = 0;
	foreach (Face face in solid.Faces)
		if (face is PlanarFace pFace)
			Mesh mesh = pFace.Triangulate();
			for (int tN = 0; tN < mesh.NumTriangles; tN++)
				var tri = mesh.get_Triangle(tN);
				var pT = new int[3];
				for (int vN = 0; vN < 3; vN++)
					var p = tri.get_Vertex(vN) * k;
					if (p.Contain(listVectors, out XYZ pF, out int index))
						pT[vN] = index;
					else
						pT[vN] = indV;
						listVectors.Add(p);
						indV++;
				listTri.Add(new(pT[2], pT[1], pT[0]));
		else
			allPlanar = false;
			break;
	return allPlanar;
 Is there a way to get a triangulated surface from a Face that is not a PlanarFace?
ricaun
What do you mean with 'it only works with PlanarFace' ?
The Triangulate method is from the Face class, all faces can be triangulate to a Mesh.
You can replace in your code the PlanarFace to Face and should work.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
ankofl
I feel pretty stupid, it seems about a year ago I added this check to PlanarFace to get it Normal() so that I could then perform the extrusion, but after a while I apparently forgot that the restriction only applies to Normal() and Triangulate() works correctly in both cases.
Funny, thing is, it was so long ago that I was getting Solid without Non-PlanarFaces and then filling the holes through CGAL.
Thanks for the reply)
