How to transform three-dimensional coordinates into two-dimensional coordinates
846081597
846081597
Hi,i i have no idea when i want to transform three-dimensional coordinates into two-dimensional coordinates,thie following is my code:
Reference refFace = uidoc.Selection.PickObject(Autodesk.Revit.UI.Selection.ObjectType.Face, "Please select a face!");
CurveArrArray cutProfiles = new CurveArrArray();
CurveArray cutCurves = new CurveArray();
Element elem = doc.GetElement(refFace);
GeometryObject selectedGeoObject = elem.GetGeometryObjectFromReference(refFace);
selectedFace = selectedGeoObject as Face;
EdgeArrayArray edgeArrays = selectedFace.EdgeLoops;
foreach (EdgeArray edges in edgeArrays)
foreach (Edge e in edges)
cutCurves.Append(e.AsCurve());
cutProfiles.Append(cutCurves);
CurveArray path= new CurveArray();
Line line =Line.CreateBound(new XYZ(0,0,0),new XYZ(10,10,10));
SweepProfile Sprofile = application.Create.NewCurveLoopsProfile(cutProfiles);
Sweep sweep = doc.FamilyCreate.NewSweep(false, path, sketchPlane, Sprofile, 0, ProfilePlaneLocation.Start);
it is failed,i find the curve in cutProfiles is three-dimensional and the profile in sweep need two-dimensional, i need your help,thankyou.
Revitalizer
Thank you for your help. Now i can get the function GetTransformToZ() in jeremytammikk's code,however jeremytammikk says that"Applying the transform to the polygon is achieved by applying it individually to each vertex." with the code
List<XYZ> polygonHorizontal     = ApplyTransform( polygon, t );
i'm not quite understand it ,i hope to get your help again,thankyou.
Revitalizer
the method's argument is just a normal vector.
If your selectedFace is a PlanarFace, you can simple use its FaceNormal property.
Transform transformToZ = GetTransformToZ((selectedFace as PlanarFace).FaceNormal);
To get a transformed Curve, just use
Curve yourCurveFlatten=yourCurve.CreateTransformed(transformToZ);
Revitalizer
Edit:
Some Revit API methods and classes have been renamed since 2008, so you may have to adjust the TBC sample code.
Rudolf Honke
Software Developer
Mensch und Maschine
Revitalizer
as you can see in Jeremy's posting, this method just transforms the curves to a horizontal plane, but Z coordinate may be not zero.
Since you have not only vertices but curves, you cannot simply drop the Z value for projection to zero plane.
You may add another Transform by Transform.CreateTranslation(new XYZ(0,0,-whatever)).
Note that there might be little inaccuracies when transforming geometry, so the end points of your resulting curves may have Z values of 0.000000001 or so.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
JimJia
Thanks a lot for Revitalizer's sharing and reply, I believe this can solve the desired transform.
@846081597 Please let us know if you still have any problem; we may communicate offline via QQ if necessary.
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
Thanks for your help,i've solved the problem.Heart
