How to Simulate Join Geometry Between Host and Linked File Using Revit API?
127_mariz_amgad_habib
Community Visitor
Community Visitor
Hi everyone,
I'm working on a Revit project where the architecture model is the host, and it contains a linked structural model. In the architectural model, I have brick walls that are attached to levels and intersect with Double T slabs in the linked structural file.
My Goal:
I want the architectural walls to be cut by the slab shapes in the linked model — similar to what would happen if I used Join Geometry between the walls and slabs. However, Revit doesn't allow Join Geometry between host elements and elements in a linked file.
What is the best approach using the Revit API to simulate a Join Geometry operation between elements in the host model and geometry from a linked file?
TripleM-Dev.net
Hi @127_mariz_amgad_habib ,
How would you do it in the UI =>
A. edit the host model by lowering the walls so they don;t intersect the structural components.
 OR
B. Cut the walls with a void family that matches the intersecion with the structural components.
In the API: (in short)
A; detect the intersections (ElementIntersectsSolidFilter) and report back to user what should be edited.
B: as A, detect the intersections and place the void family (could be a simple rectangle Void cut family) and cut the wall.
Doing this in the API will be no simple task, I have created a VoidCut intersection tool, but don't let it cut all, I use it to make opening in walls where beams go thruw the wall.
If a wall clashes with structural components over almost the full length of a wall, I just reduce the height of the wall.
Note: ElementIntersectsSolidFilter is only the end part of finding the intersection a lot code is needed to get to that point.
I hope this points you a bit in the right direction.
- Michel
