How to set smooth line with anti - aliasing for Current View ?
Hi everyone,
I am trying to set the smooth line with anti - aliasing  for the active view by following code:
                                viewForPreview.AreAnnotationCategoriesHidden = true;
                                viewForPreview.AreImportCategoriesHidden = true;
                                viewForPreview.DetailLevel = ViewDetailLevel.Fine;
                                viewForPreview.DisplayStyle = DisplayStyle.Realistic;
                                ViewDisplayModel displayModel = viewForPreview.GetViewDisplayModel();
                                displayModel.EnableSilhouettes = false;
                                displayModel.SmoothEdges = true;
                                displayModel.ShowHiddenLines = ShowHiddenLinesValues.ByDiscipline;
                                viewForPreview.SetViewDisplayModel(displayModel);
But when I run the code, there was an error : " the silhouette line style id is not a valid line style to apply to the view" :
If you have any experience with this problem, please help me.
Thank you so much for your help.
Best Regards,
Ninh Truong
Moustafa_K
hi,
you need to first set the linestyle of the Silhouette Edges, so that enabling the Silhouette have a proper line style to display
var lstyles = new FilteredElementCollector(doc).OfClass(typeof(GraphicsStyle));
var lstyl = lstyles.Where(o => o.Name.Contains(mylinestylename)).FirstOrDefault();
displayModel.SilhouetteEdgesGStyleId = lstyl;
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
michael-coffey
I'm having this same issue.  @Moustafa_K You said that "you have to set a line style to enable them" but you can cleary see in the sample code that Silhouettes are being set to false:
  Why would the line style need to be set?
In Revit Lookup, the line style returns a value of "< null >".  Setting null returns a different error that states that it can't be set to null.  Using ElementId.InvalidElement doesn't work either.  Has anyone figured out a workaround?
