How to set "Pinned" to yes
studio-a-int
studio-a-int
Hello -
I'm iterating through a list of selected elements and I want to Pin/UnPin them.
If I run:
PIN_STATUS = [i.Pinned for i in my_selection]
I get a list of
[true, false, true, true, ... ]
In the API the method is
Pinned { get; set; }
But I could not make it work.
(I have the transaction started and ended before and after)
Help greatly appreciated.
Thank you.
matthew_taylor
Hi @studio-a-int,
Unpinning works using this method:
Dim e As DB.Element = ...
If e.Pinned Then
       e.Pinned = False
So, this should work the other way...:
If not e.Pinned Then
       e.Pinned = True
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
studio-a-int
Found the solution:
[Element.Pinned.SetValue(i, True) for i in my_selection]
studio-a-int
Matt -
thanks for your reply.
As I mentioned, I found the right syntax right after posting.
And that is because, I'm using Python for initial coding work (takes a bit to translate from C# to Python).
PIN_SELECTION  = [Element.Pinned.SetValue(i, True) for i in my_selection]
or
UNPIN_SELECTION  = [Element.Pinned.SetValue(i, False) for i in my_selection]
