how to Set Instance-Based Height Parameter for Wall Panel Family via pyRevit Script
sHubamyadav016
Message 1 of 1
sHubamyadav016
I’ve created a Revit wall panel family (.rfa) that includes an instance parameter named Height. The panel geometry is designed to flex based on the value of this parameter.
Now, I want to use a pyRevit script that performs the following:
  1. Asks the user to input a custom height in millimeters.
  2. Places an instance of the wall panel family at a picked point.
  3. Sets the Height parameter of the instance dynamically to the user’s input.
I have confirmed that:
  • The family is properly parameterized with an instance Height (Length) parameter.
  • The panel flexes as expected when manually editing Height in the properties panel.
  • The script should prompt for height (e.g., via forms.ask_for_string()).
  • Convert the input to feet (Revit internal units).
  • Place a family instance at a picked point.
  • Set the Height instance parameter to the provided value.
I’ve written some basic script using FilteredElementCollector and NewFamilyInstance, but I’m unsure how to:
  • Properly access and set the Height instance parameter
  • Handle unit conversion
  • Ensure family is activated if not already
Replies (0)
