How to select only Independent tags and Textnotes from the current document with using PickObjects(ObjectType.Element, new MassSelectionFilter()); method .
praveen.cMXB2H
praveen.cMXB2H
I can select only independent tags with using given below class but i want to select independent tags and TextNotes.
public class MassSelectionFilter : ISelectionFilter
public bool AllowElement(Element element)
return element is IndependentTag ;
public bool AllowReference(Reference refer, XYZ point)
return true;
with using above method i can able to select only independent tags or Textnotes but i want to select both.
jeremy_tammik
You can implement the AllowElement method to return true when the desired element type is detected, e.g., a tag or text note.
I would strongly recommend renaming the selection filter so something other than MassSelectionFilter. The name MassSelectionFilter would seem to indicate that only mass elements can be selected.
