How to save Family to a new file
petarQ6NCX
petarQ6NCX
Using Revit API and without using Revit UI, I want to save a loaded family into a new file.
Let's take a look at the following code:
 using (Transaction transaction = new Transaction(document))
            transaction.Start("Load and Save Family");
            if (document.LoadFamily(familyFullPath, out Family family))
                Console.Writeline("Load successful")
            transaction.Commit();
            ModelPath newPath = ModelPathUtils.ConvertUserVisiblePathToModelPath("result.rfa");
            SaveAsOptions saveAsOptions = new SaveAsOptions();
            family.Document.SaveAs(newPath, saveAsOptions);
The problem with this code is that it saves the default document in which we load the family, because family.Document is returning "the document in which the element resides".
What I want is to save only the loaded Family as a new .rfa document.
To explain better, I will demonstrate how that looks like when using Revit UI:
How can I achieve the same thing but purely with Autodesk.Revit.DB?
petarQ6NCX
Ok, the solution is to use EditFamily.
So the following code will save the family to a new, separate document:
            var famDoc = document.EditFamily(family);
            famDoc.SaveAs(newPath, saveAsOptions);
And for explanation: EditFamily  "creates an independent copy of the family for editing", and while we have the independent copy, we can save it. 🙂
Mohamed_Arshad
HI @petarQ6NCX
  You can Edit the Family, That Method will return you the FamilyDocument. Kindly check the below code for additional reference.
Reference Code:
            //Edit Family which you loaded Will Return you a Family Document
            //Kindly Save the Family Document as .rfa
            Document familyDoc = doc.EditFamily(fam);
            familyDoc.SaveAs(newPath, saveAsOptions);
Hope this will Helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
Mohamed_Arshad
oops you've already posted 😊
Mohamed Arshad K
petarQ6NCX
Yes, but thanks for the answer anyway! 🙂
