how to rotate a FamilyInstance around 3 axes
dirk.neethling
Message 1 of 8
dirk.neethling
Can anyone please show me how to rotate a FamilyInstance derived from Metric Generic Model.rft about the 3 axes?
Replies (7)
Message 2 of 8
Hi dirk,
You can use like this
Let say familyinstance =fin
 1st  : Get Family Instance Location point (LP)
 2nd  : Now create unbound line according to direction(X,Y,Z) Like.
     XBasis=Line.Create(LP, fin.GetTransform().BasisX)
     YBasis=Line.Create(LP, fin.GetTransform().BasisY)
     ZBasis=Line.Create(LP, fin.GetTransform().BasisZ)
 3rd : Rotate Element
     ElementTransformUtils.RotateElement(document, element.Id, XBasis,Angle)
     ElementTransformUtils.RotateElement(document, element.Id, YBasis,Angle)
     ElementTransformUtils.RotateElement(document, element.Id, ZBasis,Angle)
Note: Can you explain more about "derived from Metric Generic"
This may help you
Message 3 of 8
dirk.neethling
 "derived from Metric Generic" just means I use the "Metric Generic Model.rft" template to generate the Family.
Message 4 of 8
Oh,
I think you derived metrices for rotation.
I hope this will solve your issue.
Message 5 of 8
paulight
Observer
Observer
Singh,
Your code lines are simple and good.  What program are you coding in?
Thanks!
Message 6 of 8
ivo.lafeber
where do you get the Angle which is used in ElementTransformUtils.RotateElement(document, element.Id, XBasis,Angle) ?
Message 7 of 8
jeremy_tammik
where do you get the Angle... ?
I would guess from the same place as you, when you ask how to rotate a FamilyInstance around 3 axes... What rotation? Which axes?
Neither the question nor the answer specify any details, so the answer matches the question well.
Orientation in 3D space requires you to provide some pretty specify input in order to be able to discuss it at all, cf.,
Message 8 of 8
sragan
Not really a programming comment, but let's also not forget 3D rotations are not commutative.
Rotating around one axis and then another is not necessarily the same as rotating around the second axis and then the first.
It's almost like adding 2+3+4 and then adding 2+4+3 and getting different answers.
