How to retrieve the Status and Reference Type of linked files in the document?
LinkedDocs.PNGI can get the linked files by using FilteredElementCollector(doc).OfClass(RevitLinkInstance), but is it possible to get the Status and Reference Type?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Try using the below code
 FilteredElementCollector Col = new FilteredElementCollector(doc).OfClass(typeof(RevitLinkType));
                foreach(Element e in Col)
                    ExternalFileReference fileRef = e.GetExternalFileReference();
                    //TO GET STATUS
                    string status =fileRef.GetLinkedFileStatus().ToString();
                    //TO GET REFERENCETYPE
                    string rTYPE = e.get_Parameter(BuiltInParameter.RVT_LINK_REFERENCE_TYPE).AsValueString();
If this helped solve your problem please mark it as solution, so other users can get this solutions as wellSmiley Happy
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Thanks a lot!
Do you how to get the names of linked files?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Yes, you can get the name using
 RevitLinkType RLT = e as RevitLinkType;
string name=RLT.Name;
Naveen Kumar T
