How to retrieve the cropBox's coordinates of a section view?
maisoui
Message 1 of 11
maisoui
I'd like to retrieve the coordinates of a section view's cropBox.
(in red on the image below)
I have tried several things for a few hours, and I still have not found a solution. I read a lot of posts on this forums or on the Building Coder blog, but I run out of idea.
BoundingBoxXYZ box = view.cropBox;
Transform transform = box.Transform;
Does anyone have a solution?
Jonathan
Replies (10)
Message 2 of 11
The builtincategory is OST_Viewers and it has a boundingbox with a min and max value. Is that what you need ?
Message 3 of 11
maisoui
I have the Min and Max box of the 3d box with view.cropBox, but my problem is how to compute the points of the polygon (rectangle) of this box in the 2d (section or elevation) view?
Jonathan
Message 4 of 11
Message 5 of 11
maisoui
Thank you for your replay. I read all these posts and I guess I tried all the combinations of transformations/projections, but I'm not able to retrieve the correct coordinates of Min and Max points in plane view.
Does anyone have a code snippet or a suggestion?
Jonathan
Message 6 of 11
maisoui
Finally I found a solution. Maybe it could help somebody:
private IList<XYZ> computeBound(BoundingBoxXYZ box, Plane plane)
	double width = box.Max.X - box.Min.X;
	double height = box.Max.Y - box.Min.Y;
	IList<XYZ> points = new List<XYZ>();
	points.Add(box.Transform.OfPoint(box.Min));
	points.Add(points[points.Count - 1].Add(plane.XVec.Multiply(width)));
	points.Add(box.Transform.OfPoint(box.Max));
	points.Add(points[points.Count - 1].Subtract(plane.XVec.Multiply(width)));
	//project points on plane
	for(int i = 0; i < points.Count; ++i)
		points[i] = plane.ProjectOnto(points[i]);
	return points;
To project a point on a plane, read this : http://thebuildingcoder.typepad.com/blog/2014/09/planes-projections-and-picking-points.html
Jonathan
Message 7 of 11
desdinova
Hi Jonathan
Could you share ProjectOnto Method ?
Thanks in advance...
Message 8 of 11
maisoui
Here is the code from the link provided:
(Jeremy's blog: http://thebuildingcoder.typepad.com/blog/2014/09/planes-projections-and-picking-points.html)
/// <summary>
  /// Return signed distance from plane to a given point.
  /// </summary>
  public static double SignedDistanceTo(
    this Plane plane,
    XYZ p )
    Debug.Assert(
      Util.IsEqual( plane.Normal.GetLength(), 1 ),
      "expected normalised plane normal" );
    XYZ v = p - plane.Origin;
    return plane.Normal.DotProduct( v );
/// <summary>
  /// Project given 3D XYZ point onto plane.
  /// </summary>
  public static XYZ ProjectOnto(
    this Plane plane,
    XYZ p )
    double d = plane.SignedDistanceTo( p );
    XYZ q = p + d * plane.Normal;
    Debug.Assert(
      Util.IsZero( plane.SignedDistanceTo( q ) ),
      "expected point on plane to have zero distance to plane" );
    return q;
Regards
Jonathan
Message 9 of 11
miguelmachadoecosta
	return points;
It helped me, but I had to do a few adjustments, depending on the view direction:
Public Const _eps As Double = 0.000000001
Private Function ComputeBound(box As BoundingBoxXYZ, plane As Plane, reverse As Boolean) As IList(Of XYZ)
    Dim width As Double = box.Max.X - box.Min.X
    Dim height As Double = box.Max.Y - box.Min.Y
    Dim points As IList(Of XYZ) = New List(Of XYZ)()
    Dim vector As XYZ
    If Math.Abs(plane.Normal.X) < _eps Then
        vector = New XYZ(width, 0, 0)
    Else
        vector = plane.XVec.Multiply(width)
    If reverse Then vector = vector.Multiply(-1)
    points.Add(points(points.Count - 1).Add(vector))
    points.Add(points(points.Count - 1).Subtract(vector))
    For i As Integer = 0 To points.Count - 1
        points(i) = plane.ProjectOnto(points(i))
    Next
    Return points
End Function
My criterion for reversing is:
Dim reverse As Boolean
If View.RightDirection.X < 0 Then reverse = True
Message 10 of 11
AmitMetzk
With the help of Remy van den Bor comment and Revit Lookup
i noticed that the viewSection BoundingBoxXYZ is different from the crop Region BoundingBoxXYZ.
viewSection in revit lookup -> Snoop Active View -> BoundingBox
crop Region in revit lookup -> Select the crop Region -> Snoop Current Selection -> BoundingBox
we need the crop Region (which is OST_Viewers Category) in order to retrieve the cropBox's coordinates
here is the code i used to get it
//Retrieve Section view
ViewSection sec = doc.ActiveView as ViewSection;
//Retrieve Crop Region BoundingBox
ElementCategoryFilter filter = new ElementCategoryFilter(BuiltInCategory.OST_Viewers);
IList<ElementId> dependants = sec.GetDependentElements(filter);
ElementId viewrId = dependants.First();
Element viewer = doc.GetElement(viewrId);
BoundingBoxXYZ secBoundingBox = viewer.get_BoundingBox(sec);
XYZ topRight = secBoundingBox.Max;
XYZ bottomLeft = secBoundingBox.Min;
XYZ diagonal = topRight - bottomLeft;
XYZ rightDirection = sec.RightDirection;
XYZ upDirection = sec.UpDirection;
double width = diagonal.DotProduct(rightDirection);
double height = diagonal.DotProduct(upDirection);
XYZ bottomRight = bottomLeft + width*rightDirection;
XYZ topLeft = topRight - width*rightDirection;
Message 11 of 11
ntopo7
Hi, this works for me, but not in all section views orientation
Im missing something?
    private IList<XYZ> computeBound1(BoundingBoxXYZ cropBox, Plane plane, Autodesk.Revit.DB.View view)
            bool reverse = true;
            if(view.RightDirection.X < 0)
                reverse = true;
            else
                reverse = false;
            double _eps = 0.00000000;
            double width = (cropBox.Max.X - cropBox.Min.X);
            double height = (cropBox.Max.Y - cropBox.Min.Y);
            points.Add(cropBox.Transform.OfPoint(cropBox.Min));
            XYZ vector = new XYZ();
            if (Math.Abs(plane.Normal.X) < _eps)
                vector = new XYZ(width, 0, 0);
            else
                vector = plane.XVec.Multiply(width);
            if(reverse)
            {  vector.Multiply(-1); }
           points.Add(points[points.Count - 1].Add(vector));
           points.Add(cropBox.Transform.OfPoint(cropBox.Max));
           points.Add(points[points.Count - 1].Subtract(vector));
           for (int i = 0; i < points.Count; ++i)
           return points;
Its works in some sections but i get this diagonal lines in other views:
any ideas?
